跳转到主内容
加入维修社区 - 创建账户
The first generation Honda CRV, produced from 1995 to 2001.
Back up light switch location
Hi guys,
i hope you’re all well!
Im having issues with the back up light switch. It needs replacing. Apparently I can not find the exact location. The engine is 2.0 liter 147 hp manual transmission. If anyone can share exact location or even photos that would be great!
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I think it’s the one on the darkest photo?
完成的
Hi @stoyanr
Your pictures did not show up.
Try posting them again in your question above. Click on Options > Edit > in the Question description bar click on "insert image" icon and follow the prompts.
Alternatively see the link @oldturkey03 provided below
完成的
添加一条评论
2个答案
已选择的解决方案
Hi again guys!
Thanks for the help!
I found the bastard, it’s located right under the air filter plastic housing. Just unscrew the two bolt on the top of the housing and the unplug the air intake hose.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi @stoyanr ,
See the Most Helpful Answer in this link
Why my reverse (backlight) won't work?
这个答案有帮助吗?
得分 1
5条评论:
Hi, I went through this topic but still struggling to locate the exact location.
完成的
@stoyanr it is located on the transmission housing. If you are unsure, take plenty of good pictures of your transmission etc. and post those with your question. Use this guide 在已经存在的问题里加入图片 for that. We most likely can point it out to you. What is the exact year of your CRV?
完成的
Hi @oldturkey03,
Thanks for the recommendation. Once I get back home I’ll take photo and post them here. It’s 1999
完成的
Is it on the top side of the housing or on the bottom side? Shall I go underneath the vehicle?
完成的
@stoyanr it should be on the top half of it. I don't think it will be underneath but it will never hurt to see to much.
完成的
添加一条评论
添加你的答案
Stoyan Stoyanov 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 32
总计 3,434
