跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 个问题 查看全部
Moisture stuck inside the screen
I have a M261VP Vizio TV not that it matters but I think I have water or a stain trapped between layers of my TV any help? Please I am in a tight situation and cannot afford to get another TV.
This problem has occured yesterday, I do not know how the only thing I remember doing to it was wiping the screen down with a wet cloth then immediately drying it afterwards.
Update (09/02/2018)
this is the image
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
19条评论:
@runj that does not quite look like moisture. Take another image but zoom out. no reason to be this close to whatever it is. We need to be able to see more of your screen.
完成的
@oldturkey03 Of course
完成的
@oldturkey03 those two dots above the play button on the first post
完成的
@oldturkey03 And by the way if there is any solution to this I will happily be able to email. I'm willing to try anything but I do not have much experience opening up my TV and tinkering with the components so I do not think that is an option if there is any more information you need just ask I am willing to provide.
完成的
@runj this really does not look like moisture....
完成的
显示更多的14条评论
添加一条评论
1个答案
Take a hair dryer and press it lightly against the screen “I had the same problem with a Vizio tv.”
这个答案有帮助吗?
得分 0
5条评论:
Okay I will try this thank you
完成的
@magicjet_ how long?
完成的
@magicjet_ This did not work
完成的
@magicjet_ If it did not work might it be that its not moisture and its something else?
完成的
It’s probably something else...
完成的
添加一条评论
添加你的答案
Jordan R 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 18
总计 1,844
