跳转到主内容
White screen of death
My macbook pro just won’t show anything except whitescreen, with no apple logo whatsoever upon booting up. I tried holding down option key, command + control + P + R, none of them work. For more details, my HDD is entirely new with no macOS installed, has no battery and trackpad. I can’t install macOS like this, please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Really, “White screen of death”,? All this means is that you don’t have a valid operating system.
Your drive has to be formatted before you can install a system on it.
You don’t need the trackpad if you have a USB mouse.
Do not install High Sierra, go with Sierra and tell us the make and model number of the new drive and why you are replacing it, does the old drive still function?
这个答案有帮助吗?
得分 2
7条评论:
I formatted the new drive to exFAT already, also the old drive is the same, nothing happened pressing option key during boot.
完成的
exFAT is a Windows format and while it will work externally as a boot drive, it will not work internally in a Mac. Format it it GUID, MacOSX journaled
完成的
i tried formatting my hdd to HFS+ using Paragon NTFS to HFS+ on windows, doesn't seem to be working.
完成的
完成的
can't say for sure, the old drive is usable on windows as NTFS, there's no way for me to check if it works in HFS+
完成的
显示更多的2条评论
添加一条评论
Format the Hard Drive / SSD correctly, then try and install macOS Sierra on it, don’t do Mojave or High Sierra unless you are a brave soul and have nothing to lose! If you have a USB mouse the trackpad is not necescery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chimera405 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 4
总计 685
