Ice maker not getting water. It goes to the cylinoid but not up to th
Water goes to the cylinoid, but doesn't go up to the freezer now. It did once after I replaced the cylinoid set up but now it doesn't, help!!
Cause 1
Dispenser Control Board
The dispenser control board governs most of the functions of the dispenser system. If only one dispenser part is not working, it is probable that an individual part has failed. In this case, test each of the dispenser components before testing the control board. If the entire dispenser system is not working, the control board is more likely to be at fault.
Cause 2
Dispenser Switch
The dispenser switches send voltage to the dispenser. If one of the dispenser switches is defective, the dispenser will not work. To determine if a dispenser switch is defective, use a multimeter to test each switch for continuity. If a dispenser switch does not have continuity, replace it.
Cause 3
Door Switch
The door switch turns off the ice and water dispenser when the refrigerator door is open. If the door switch fails, the dispenser will not turn on. To determine if the door switch is defective, use a multimeter to test it for continuity. If the door switch does not have continuity when activated, replace it.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 41
