跳转到主内容
Transplant the SSD to another MacBook
So I’ve been trying to recover a liquid damaged MacBook Air, and it looks like the cost of replacing the parts has exceeded the cost of purchasing a refurbished MacBook Air of the same generation.
If I took the SSD out of the damaged system, can I simply plug it into the new Mac and expect it to play as if there were no changes at all?
At first, I imagine the SSD will most likely detect that it’s in a new device, but will the OS still load and my data still be available?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I’ve done this before, after my 2014 Mac Air did not turn on. Repair was not economical, and I had a spare 2015 available. Both had the same OS version, so that probably helped, but the only thing I remember really having to do was confirming licenses for a few of the apps I had installed, and confirming my Apple ID details.
I’m actually about to try this again, as my Mac air has 4GB, and we have an 8GB version that would suit me better. 4GB is plenty for our staff that really just use Google Office. I have, of course, backed everything up before starting, and have all my license keys saved.
完成的
添加一条评论
2个答案
最有帮助的答案
Consider getting an OWC Envoy Pro enclosure, then you would be able to access it on another Mac plus have a fast external drive for backup or utility purposes.
https://eshop.macsales.com/item/OWC/MAU3...
A lot of people buy these to use to transfer data for an old machine and then sell them on eBay.
这个答案有帮助吗?
得分 1
添加一条评论
If you had High Sierra on your liquid damaged system you may encounter a problem trying to swap out the SSD. During the OS update your systems firmware was upgraded as well so it can handle the new APFS formatted drives. So you’ll need to first make sure your new system is running High Sierra before you try.
I still think getting the OWC Envoy Pro case @mayer recommends is a better answer! Then you can leverage the SSD as a backup drive or offer a large transfer drive if you have a iMac system as well.
Here’s a good reference on the Apple SSD’s The Ultimate Guide to Apple’s Proprietary SSDs (Gen4)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Paul Ko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 282
