跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Replacing A1660 logicboard with an A1778 on an iPhone 7
Is it possible to replace an A1660 motherboard, with an A1778 one? I destroyed the baseband pad, on my phone’s A1660 logicboard and i need a cheap replacement. The only thing i found, is a model A1778 logicboard. Will the replacement work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
A1778 ka motherbord ha?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Yannis!
Physically, the board will fit fine. Bear in mind however that the models are differentiated primarilly by which modem they use - Qualcomm or Intel. So, it should fit just fine. I would also expect it to work fine, but there may be some performance differences. You’ll also want to be certain that the replacement board comes with its original home button or your Touch ID will not work. Finally, be sure that the replacement board is not iCloud locked or you’ll have a whole new headache.
Cheers!
Joshua
这个答案有帮助吗?
得分 1
2条评论:
Thanks a lot Joshua. Your answer was pretty informing.
完成的
You bet! Glad to help!
完成的
添加一条评论
添加你的答案
Yannis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 670
