跳转到主内容
Ring Video Doorbell Model No. 88RG000FC100
16 个问题 查看全部
Charging cable does not charge the battery anymore
The unit was operating normally, but the supply transformer is dead, likely due to overload, and a replacement transformer sees a high current flow. At 0,5 Amps AC, only 1 Volt at the Ring terminals. How to repair the circuit board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Alain Rouquet your measurements of amperage and voltage is from the power supply transfomer or the door bell itself? where did you measure?
完成的
The measurement are made on the cable supplying the Ring.
this cable has a total resitance of 2,1 ohms (telephone wire)
On the transformer terminals, there is 9,65V under this load,
then I have 2 resistors of 10 ohms each, which drop 3,92V each, so I have 1,8V at input of the cable, and by calculation about 1 V on the Ring terminals.
完成的
Hi Alain Rouquet.
What is the transformer voltage with no load?
Have you measured the voltage at the Ring terminals?
According to the info on the battery for your doorbell (assuming it is the same one as featured in the ifixit link) the battery requires 8-24VAC or 5VDC @1A and according to your measurements you are supplying about 3.9A.
Post some close up pictures of the motherboard so that it can be seen if there are any obvious problems.
Here's how to do this 在已经存在的问题里加入图片
You probably don't need this but here's a link to the ifixit Ring Video Doorbell Motherboard Replacement guide which may be of some help in gaining access to the motheboard
完成的
0,39 Amps, not 3.9 Amps .
I will disassemble the Ring in October to check what went wrong on the mother board, and either repair this AC supply or arrange a 5V DC supply through the USB charging...!
完成的
添加一条评论
1个答案
If your Ring Video Doorbell is not ringing correctly or is no longer working, use the Ring Video Doorbell Won’t Turn On problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alain Rouquet 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 23
总计 892
