跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Mac OS X Lion to el capitan
After two tries on downloading el Capitan to my mac it comes as a folder in finder, but when I click it, it says something by the lines of “the following disk images couldn’t be opened”.
So, i’m not really sure what to do. My goal is to end up with High Sierra, is there any other way to go from X Lion to High Sierra, or is there a way to download el Capitan in 2018 with out the same problem that i’ve been having previously?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Please tell us the exact MacBook Pro you have. To get that information you can plug in your serial number from the back of the machine here and it will tell you what you have: https://everymac.com/ultimate-mac-lookup...
完成的
It says MacBook Pro "Core i5" 2.5 13" Mid-2012
Is this what you mean?
完成的
添加一条评论
1个答案
If you have a good internet connection why don’t you just use internet recovery to install the newest OS. Here’s more on it: How to reinstall macOS
But you may have a deeper issue here! The 13” Unibody MacBook Pro’s tend to have issues with its HD SATA cable. I strongly recommend you replace it if you just upgraded your drive. Here’s the part you’ll need: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable. You’ll want to place some electricians tape un the uppercase where the cable crosses over. The rough surface of the aluminum case tends to wear the cable. You also don’t want to over fold the cable you want smooth arcs not sharp corners.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable图片
产品
$34.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sophia Jeffery 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 207
