跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
Why won't my PS4 Pro stay on
When I turn on my Playstation 4 Pro, it will beep, the light will turn on and be blue but immediately shut off. I then have to unplug my console from the back, wait a few seconds, plug it back in, and turn it on again only to have the same thing happen again.
I tore down my console and cleaned it as much as I could and put it back together to no avail.
What could be the problem? Is it the PSU?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
I recommend having a look at this guide here on IFixIt!
PS4开机瞬间关机的修复方法
这个答案有帮助吗?
得分 0
添加一条评论
That could be the issue, it’s also a symptom of a bad apu. What happens is the solder balls on the APU Will overheat and sometimes crack causing a Loss in APU functionality Which leads to the device being turned off immediately during the self check portion of the initial start up. If you’ve already replace the power supply and you’re still having the issue then it’s probably the APU you can try installing some washers around the area of the APU which will clamp down the chip and Hopefully restore The current flow through the chip and fix your issue but if not you’ll most likely have to have your APU reflowed. Look online for ps4 apu quick fix with washers and you can try it out.
这个答案有帮助吗?
得分 0
添加一条评论
Hello guys!
As late as I am(about 3 years since the first post :)) ), I found a solution to this same problem.So after cleaning my ps4 pro ,I placed back the power supply ,but didn’t pay attention to the 2 silvery connectors that should fit inside the power supply, each with its own place, and bent one of them down touching the other one.This way the power wasn’t flowing as ps unit was seeing a shortcircuit.So I got both straighten up ,fitted each in its own hole and my PS4 PRO is back in action.Hope this helped !Good luck and Have fun!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Corey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 1,151
