跳转到主内容
change of hdd did not work.
I went to the computer tech here at my college because by MacBook Pro turned off by itself and when I turned it back on, it gave me a blinking folder with question mark. They suggest that I should change the HDD. So I bought the HDD and have them replace it. They ran a test and it passed the test on the new one and the old one. So they don't know is. I would just like to know if you know what the problem is.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Will it start up from the system installation DVD?
完成的
yeah it will start from the installation DVD but when I do try to install it, it says that it can't install because there is no hdd found. The same happened with the new hdd. It's such a hassle not having a laptop since finals is in two weeks!!!
完成的
添加一条评论
1个答案
已选择的解决方案
If the hard drives are good and it runs off the DVD, I would replace the hard drive cable. Check it's connectors first. Here's the cable: MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable图片
产品
$34.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
keenacirilo1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,267
