跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Help identify iPhone 8 logic board components
I have an iPhone 8 that will not come on I’ve identified one of the components close to the battery port connector (RV3C002UN) but am having trouble identifying another component to its immediate left. A mirror/silver like chip was actually broken and without a schematic it is very difficult to identify. If anyone could possibly help it would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@blaked89 you can make this "the components close to the battery port connector"and "A mirror/silver like chip " a lot easire by posting a picture with the broken component marked. that way people like @refectio can probalby identify this in no time at all. Use this guide 在已经存在的问题里加入图片 to post some images.
完成的
Ok thanks, until recently I only read posts but I finally found an issue I could not find myself so I just had put the question out. So first post here. I could upload a picture tomorrow if the pads on the board but the component itself was more or less shattered. The schematic from Minho seems to be the one I’m looking for But I will certainly let everyone know once I find out. I didn’t read his post till after our shops close.
完成的
添加一条评论
1个答案
已选择的解决方案
In general, a shiny glass component is usually a diode or a MOSFET. Check the screen capture of the iPhone 8 Plus schematic below. There is very little difference between regular and plus models on the basic circuitry.
这个答案有帮助吗?
得分 2
3条评论:
Thanks, I really appreciate it. I’ll look into it as soon as possible and let you know if I can find it.
完成的
So i believe it is a TVS but I dont want to post the number/name of the component until I am %100 sure that’s the component that was damaged. Customer is becoming anxious, not sure if I will still have the phone by the time the part comes in. Very fine time limit I am working with lol
Thank you so much for the information and schematic but I do not want to mislead anyone. Will have to update you when it is confirmed. I do apologize.
完成的
Were you ever able to identify the name of that shiny glass component?
完成的
添加一条评论
添加你的答案
Blaked89 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 511
