跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
My iPhone 6 is unresponsive in places. Will a replacement screen help?
Hi, I have an iPhone 6 that I purchased from new, I had the screen replaced over a year ago and it’s always worked fine however recently the device has started to play up (I didn’t drop it or anything). Some parts of the screen still work fine, but other parts don’t respond to any touch at all.
I was wondering if I took it to a local shop to replace the screen, would it help? I have tried everything software-wise, like restoring to factory default etc.
Any help would be greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
What you are describing is indeed most likely a failing screen assembly.
A new screen assembly should resolve this. Provided you have no liquid damage.
Sometimes, you may have board failures that cause similar issues (screen intermittently fails to respond to touch), but first and foremost try a new screen.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Will 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 21
