跳转到主内容
所有的苹果便携式平板电脑的全面维修手册。维修过程可能需要加热以及细心的撬动。
5769 个问题 查看全部
Stuck in "headphones", one speaker muted otherwise
Hi!
This problem is strangly repeating on on the second iPad I had (first one was Mini 1). For no particular reason, no changes in software, absolutely no physical influence, iPad starts to think the headphones are connected (but they are NOT). I clean the jack - no changes. Do a hard reset - no luck. Than cleaning Lightning port and doing a hard reset again somehow kicks it and the sound appears but usually one of the speakers doesn’t work properly, it’s MUCH quiter so the sound is terrible.
What is that? How to fix that disgraceful for a premium device of that cost issue? I’m really upset
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
When the device believes it is in headphone mode, even without headphones connected, it is usually because one of the spring loaded contacts is permanently”pushed in”. This could be from physical damage or just gunk/dirt that makes it jam into position. Have you tried cleaning the jack with a fine point cotton swab and some IPA or are you just removing lint etc.?
The other option is to replace the headphone port.
这个答案有帮助吗?
得分 2
5条评论:
I definately did, I described it. Jack seems to have no ifluence, i suspect the Lightning port has. I have cleaned it too, but the contacts look absolutely flawless
完成的
Well, you said you cleaned it, not how you cleaned it...that makes a big difference. Some people just blow out the port and call it cleaned :>).
On the iPad mini, the headphone jack doesn't go through the lightning port, it connects directly to the logic board. Each iPad is somewhat different and you don't say what model the second one is but that's generally how they work.
完成的
I used fine cotton wrapped over a thin wood toothpick. At first attemt it was dry, that with a drop of 98% ethanol (I always use it for electronics, works fine).
完成的
Alright, that's good. That doesn't mean you don't have a potential problem with the headphone port though. If the pins are jammed inside, you will have the same symptoms. Seeing as how the iPad is more of a pain to open up, you could try pushing against the spring loaded pins inside while looking closely with a loupe or other from of magnification. If they aren't springy, that would confirm it. However, even springy pins wouldn't mean that the port is fine. Ultimately, you will probably have to open up the ipad and try a replacement headphone port.
完成的
I have Mini which is disassambled because of the same problem. And nope, the headphone jack is clean.
So... There's something else :\
完成的
添加一条评论
I think you might have a liquid damage you didn’t even notice happened
for your speaker to suddenly reduce in sound and the 3.5 mm headphone jack acting up it’s water damage bruv
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 100
