跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
White vertical lines screen partially unresponsive
The iPhone was dropped and now there are 5 vertical white lines on the right side of the screen. Where the white lines are the screen is unresponsive. However, when I diconnect and reconnect the screen I can sometimes manage to get the lines to switch to the left side and then that side becomes unresponsive.
Any ideas other than replacing the screen and digitizer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This is a connection issue. Often when connecters are not seated properly (especially on the 5 series and SE) the screen displays bars.
Id suggest removing the display, checking the connectors arnt damaged, clean the connectors with isopropyl and see how it goes from there. Also, make sure the cables are not getting twisted or stretched when laying the screen back down.
这个答案有帮助吗?
得分 1
1条评论:
Sounds like the screen needs to be replaced either way if it happens after a drop.
完成的
添加一条评论
添加你的答案
Kyle Benning 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 10
总计 302
