跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 个问题 查看全部
White thermal paste vs Arctic Silver?
Any idea why the thermal paste on the iMac video card's two RAM chips is the white spongy type, instead of something like Arctic Silver, as is used on the graphics chip itself? Can Arctic Silver be substituted for the white paste?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Most of the pros on iFixit recommend and use Arctic Silver 5. I'm sure China uses its own brand. I've seen some white powder stuff on RAM but never a thermal paste.
这个答案有帮助吗?
得分 2
2条评论:
I'd normally use Arctic Silver on everything too, especially since when I tried some cheap white paste years ago, it didn't work as well. But I'm wondering if Apple had some reason for using the odd spongy white stuff I'm seeing on the VRAM chips. One guess is that, since VRAM doesn't get as hot as the GPU, it may not need the better, more expensive stuff. But since I'm replacing the dried-out Arctic Silver-like paste that Apple used on the GPU, with actual Arctic Silver (which may not be any better than the gray paste Apple used), I figure if it can't do any harm, I'd replace Apple's white paste with Arctic Silver too, unless there's some reason not to (which I can't imagine, but I've been wrong on something once before).
完成的
I just wouldn't use thermal paste of RAM. If you're really worried about RAM heat, try using heat sinks made for RAM. You can get these for like $1.00. Here's a bunch: http://shop.ebay.com/items/ram%20heatsin...
完成的
添加一条评论
添加你的答案
johnsawyercjs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 4,241
