Where is the Atrix GPS antenna?
I replaced the digitizer in my Atrix.
Everything works great. Except my GPS is taking forever to lock on to satellites, and when it does it drops the sats constantly.
Its cloudy outside, but I have never had this problem before. According to the GPS trouble-shooting App I used, the signal is very weak. Where is the GPS antenna? Is it possible I messed up the antenna?
2条评论
I found the answer to my own question. The antenna cable in the Motorola Atrix is the only coaxial cable that plugs into the board. It is very important that the ground located in the middle of the cable be snapped into the metal clip. The clip is part of the case. If it is not connected the GPS will receive low signal and will not function.
由 Justin Blackwell 完成的
Great job Justin ;-) Congratulations. Now all you have to do is convert your comment to an answer (a simple cut and paste will do) and than accept your own answer. Get some credit for your research. Again, great job.
由 oldturkey03 完成的
