跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
Strange Display behaviour after Digitilizer and LCD swap.
Hey Everyone,
I changed the Digitilizer and the LCD on an Ipad Air as it was broken and showed nothing on the screen. After the repair it shows an uneven lightning on the left side of the screen. Attached are some pictures of the screen.
What is strange to me is that there sometimes is an even unevener lightning with only 3 spots on the left side
Some times the screen wont turn on at all and you just can restart the ipad to get it to show something again.
Has anybody had a similar behaviour and knows how to fix it?
Additional Info:
I saw this thread but won’t be able to do this repair, does anyone know if it is harmful to not fix it or a place in Germany where they can do this repair for a reasonable price?
Dark spots on left side of LCD from top to bottom?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
What you are describing we call ‘Theatre lights” and it is because one of the backlight circuits is out, so only every other LED is lighting. When it changes to a different pattern, then that means that while one circuit is completely out , the second circuit has one of the returns out temporarily broken—the incoming voltage is present for that line, but some of the split returns have the drawbridge up and are open line, so only the intact lines light whatever individual LEDs they serve.
This can happen in two common ways.
1.) MOST likely for you is bad LCD, because you are seeing changing patterns, some of the lights are working some of the time. Your next step is to order a good LCD—- be a good person and order from iFixit out of respect for the real dollars and cents that go into creating the guides you used to open the device and this free forum where you are getting the answer you need to solve your problem. eBay and Amazon parts are almost always total junk.
2.) You connected the screen while the battery was still connected. This is a huge no no. When the device is powered off but the battery is connected = you have live main voltage at the LCD connector. It takes very little effort to accidentally graze a ground pin with the hot pin when you are pressing the LCD into the connector—if that happens, you create a path to ground and generate a burst of current that zaps the backlight filter(s). If a new LCD doesn’t solve, then the next step is to send this board out to a microsolderer for backlight circuit repair which is straightforward.
这个答案有帮助吗?
得分 2
2条评论:
Hi jessabethany,
thank you for your answer!
1.) unfortunately I think its not the LCD as I tested several ones.
I would love to buy a LCD vom iFixit, as I also bought the Digitilizer there, but they don't offer LCDs for the Ipad Air in the EU-Store :(.
2.) Hmm, I think that could be the reason for my problem.
Do you know if it is bad to use the Ipad till I find some microsolderer place?
完成的
You can use the iPad. If it's not the LCD then it is backlight circuit damage for sure--ALWAYS disconnect the battery before connecting any connectors!
完成的
添加一条评论
最有帮助的答案
Hi There,
Its backlight problem on your LCD.
1- open it up again and reconnect the LCD connector again to make sure it seated properly. Any of the connection might not be connected properly.
2- make sure to check backlight flex on lcd screen is inserted properly.
If you are not a repair technician don’t attempt it. You will mess up something esle. Which could land up in more expense.
这个答案有帮助吗?
得分 3
1条评论:
Hi Shahil,
I will check if for your solutions 1 and 2 :)
Yes, you are right to don't attempt it to not damage anything more. Normally I'm not hesitating to try to fix stuff, but than at least I have the right tools and there is nothing too lose
完成的
添加一条评论
添加你的答案
Simon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 256
