跳转到主内容
加入维修社区 - 创建账户
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Vertical line screen problem 12"
hi guys
before some days that line appeared, it dissapeared than after some minutes, but it apperead for second time and didn’t disappeared yet, i have a no idea what is it and why it apperead. Do you guys have a idea why and if its only way to fix on a service how much it would be cost?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Dan, what about the problem on my laptop, it is also like that but there's a lot more lines and it generates a white background when I am closing the lid. Also, my mac is Macbook 12" Retina Early 2015
完成的
If you have a lot of lines that's at the point you'll need a new display. My Answer below give you the details.
完成的
添加一条评论
1个答案
最有帮助的答案
Ouch! You have whats called a TAB error. What happens it the LCD panel has a thin coat of metal to create the wires on the glass to the pixel locations on the screen in a grid pattern (X & Y) on the edge of the LCD screen there is an point where the signals from the driver logic needs to connect to the screen, this mechanical interface is what has failed.
Sorry to say theres just not much you can do to fix it. You’ll need to live with it or replace the full lid assembly. You might find pressing along the edge of the screen might make it disappear as you might be able to get the broken connections to bridge otherwise it is what it is.
A common cause is a bang on the edge or something heavy sat on the lid.
这个答案有帮助吗?
得分 2
4条评论:
Thanks a lot
Im a curious
Can u have a idea how much it costs in service?
完成的
Here's whats involved in replacing the screen Retina MacBook 2015 Display Assembly Replacement and here's the need part: MacBook 12" Retina (Early 2015-2017) Display Assembly
The labor will likely be somewhere around $200 US unless you do it your self.
You might want to visit an Apple Store to see what they say.
完成的
thanks a lot for information, bro
i appreciate it
i bought my laptop before a mouth for 630$
and now i got to change the display for 550$ ... impossible :D
can you say me which part exactly i have to press, i want to try this way, thank you..
完成的
Try pressing were the line is on the top and bottom.
完成的
添加一条评论
添加你的答案
reshatov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 1,464
