跳转到主内容
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 个问题 查看全部
Can you upgrade the motherboard on a Samsung S4? If so, is it tricky?
I have a samsung S4 that needs a new wifi chip. I was thinking it might be easier to simply swap out the whole motherboard. The thing was overheating and basically cooked itself, so I’m thinking that if I’m going to swap the boards anyway, I might as well upgrade the internal memory to 64gb if at all possible. Is this possible?
Phone was bought on Pixmania.ie, simcard was for the 3 network in Ireland. Not locked, not rooted yet.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you have a 16gb logic board and and a higher capacity logic board you can simply swap the logic boards if they are the same model.
If the other board is a different model it may not fit or work.
You can't upgrade the storage on these logic boards easily because it requires replacing the flash memory chip on the board and reprogramming it with a flashing box so it would be easier just to replace the logic board with a working higher capacity one.
这个答案有帮助吗?
得分 3
1条评论:
Cool, so in terms of me buying a replacement part, what do I need in this situation?
完成的
添加一条评论
添加你的答案
Eoghan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 145
