跳转到主内容
加入维修社区 - 创建账户
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
DSi won't turn on, but charging light still seems to work.
I hadn’t used my DSi for many years, and when I decided to power it up again it wouldn’t turn on. The charging light would light up solid orange when plugged in, and would eventually turn off after charging for a while, but still wouldn’t turn on. I decided to look online and figured that the problem was simply a dead battery. I ended up ordering a new one and replaced it, but the problem still wasn’t fixed. I don’t remember it going through any major water damage, but I did drop it quite a few times. Is this problem fixable? Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
use the guideline provided by iFixit to dissassembly ithe DSi and check for all the cables for corrosion or maybe seated improperly.
make sure the screens ribbon cables are fine too, since it is the common cause of dead DSi
这个答案有帮助吗?
得分 1
1条评论:
I have a problem also, i rhink screws on my dsi are messed up and sht and I am not able to open the battery compartment :(
完成的
添加一条评论
添加你的答案
Egg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,439
