跳转到主内容
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
331 个问题 查看全部
How do I turn on my iPod Touch after it fell in water?
Hi, my iPod Touch 5 fell in a pool about three years ago and it hasn’t turned on since. I want to turn it back on but it won’t. The only time I get a response is when I plug it in to a computer or outlet to charge and the low battery signal will show up signaling that it’s charging but it never turns on no matter how long I charge it. Also, when I plug it into my computer and turn on iTunes it never detects the device but it does with my working iPhone. I’ve tried holding down the power and home button for ten seconds, putting it in rice, and some other things. Does anyone have a solution for turning it back on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
same its been about 5 years and the same problem happend to me does anyone have an answer
完成的
添加一条评论
1个答案
已选择的解决方案
At the very least, this device needs a new battery. That doesn’t mean the iPod will work though as water damage, especially after such a long period of time, can cause lots of issues with the logic board. Replacing the battery does require some soldering though so caveat emptor.
I would also do the following:
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
autumn b 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 914
