跳转到主内容
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 个问题 查看全部
I've broken the DSI motherboard power connector!
I recently bought a "for parts" DSI off of Ebay. The lower screen was broken, but I'd replaced a DS lower screen and figured I could handle it. I used the instructions on this website to begin the disassembly of the unit, when I got to the point where you disconnect the power cable from the mobo (step 9) I ran into a problem: the entire connector, not just the cable, came off the mobo. Is there any way to reconnect the mount point for the power connector or is this a matter of suck it up and send it out to a repair tech? I'm going to look at under a magnifying glass and hope I can solder it back on, but I'm not certain that will work. Any suggestions most appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
5条评论
As a side note, I've noticed what appears to be either water residue or some type of glue on various parts of the motherboard. also, before the teardown, the unit did power on when plugged into a wall charger. It appeared to just be a broken LCD was the issue with this unit. (but I could be wrong)
完成的
AdamMcinturff, is there any chance you can post a pic of the damage. I think that there might be a way, if you are pretty handy. Of course you can also send it off to get it repaired, however make sure that you get a good cost estimate in order to not spend more than a replacement DSi would cost.
完成的
Just to update, it is quasi-repaired. I used alcohol to clean the motherboard and used; a flashlight, a soldering pencil, and a magnifying glass (at this point there was someone else helping, let's face it my soldering skills are only so-so) and we ever so gently soldered some extra wire directly onto the mobo and then soldered that to the connectors from the power supply board. sadly the case wont close completely (to much wire I suppose) and occasionally the thing acts as if the up or down button is constant on. any idea where I can find thinner wire?
完成的
Check a electrical supply house for thin wire. Good luck. + for your effort.
完成的
+ I second that
完成的
添加一条评论
2个答案
已选择的解决方案
replace the power button assembly or the motherboard.witch ever one
Nintendo DSi XL Motherboard图片
指南
Nintendo DSi XL Motherboard Replacement
难度:
中等
20 - 30 minutes
Nintendo DSi XL Power Board图片
指南
Nintendo DSi XL Power Board Replacement
难度:
中等
15 - 30 minutes
这个答案有帮助吗?
得分 1
添加一条评论
Hi, have the same problem.
I soldered red and black wires directly to two very little metal pads placed just on the motherboard, to the left, i mean nearer to the wifi module. But I got no result: console screen makes a little flash and then got off. I suspect there might be another connections to be made but as i've broken the whole mobo dc connector can't imagine what else.
Thank you.
这个答案有帮助吗?
得分 0
3条评论:
(I know this is old but someone might need the info)
I did the same thing but soldered underneath the board which did work, trouble was the case didn’t fit comfortable.
完成的
@void west
Can you please show a picture? I'm having real trouble with this problem and it would be GREATLY appreciated!!
完成的
I have the same problem and I have no idea what to do going forwards. Do I just solder the connector back on the board or do something else?
完成的
添加一条评论
添加你的答案
AdamMcinturff 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 21
总计 8,690
