跳转到主内容
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 个问题 查看全部
iPad will not turn on
My iPad 4th Gen has just died and will not be resurrected. I tried force restarting, but that didn’t work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
What happened to the iPad just prior to this event? Was it dropped, repaired or came into contact with water? If not, then the first thing to check would be the battery. Was it showing signs of decreased life? Unfortunately, because your iPad no longer boots, it will be impossible to run a battery diagnostic.
In this case, you will need to open up the iPad and either measure the voltage directly at the battery or replace it outright to see if that solves the problem.
这个答案有帮助吗?
得分 1
添加一条评论
What happens if you put it on charge. Note that if it is completely discharged, it may take a long time until the charging symbol appears.
More information about the standard diagnostic procedure in your case can be found here:
If your iPhone, iPad, or iPod touch won't turn on or is frozen” https://support.apple.com/en-us/HT201412
If your iPhone, iPad, or iPod touch won't charge” https://support.apple.com/en-us/HT201569
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nooby Stats 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 72
