跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
Backlight out but can still see Apple logo
Hello, I have a customer’s iMac in which he stated he heard a “pop”, and the screen went dark. I originally assumed this was the backlight fuse, which I was told is inside the display, and I have done the following and still no results.
PRAM and SMC
New Display (confirmed working on other unit)
New LED DisplayPort Cable (tested on both displays)
The Apple logo can be seen, but only under extreme light in a very very dark environment.
External monitor is only functional when the LED is not connected to the unit.
All 4 LED diagnostic lights are lit up when the unit boots.
I’m leaning towards logic board or power supply, but I don’t know where to go from here. Any help or advice would be appreciated. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
There is a backlight fuse on the motherboard near the SATA connector. You should test it with a multimeter for continuity first.
这个答案有帮助吗?
得分 1
添加一条评论
I have a iMac with exactly the same issue. I heard a ‘pop’ and the backlight went off. External monitor works fine. Alle 4 diagnostic LED are on. Image can be seen on display with a torch.
Did you have any luck reparing the iMac?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
PuPpYd0g21 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 108
