跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
How do I repair my keyboard backlight?
Keyboard backlight hasn’t been working for a while - tried resetting etc. Where is / which is cable to check to make sure it is plugged in? May have happened when battery was replaced. Can’t seem to find the answer for this mac for this cable. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The keyboard backlight connector can be seen in this IFIXIT guide: MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Logic Board Replacement Jump down to Step22
这个答案有帮助吗?
得分 1
2条评论:
Thanks. I checked that but it didn't seem to be the answer. I believe at this point I probably have to replace the whole backlight unit after 9 years of use.
完成的
Did you check the voltage with a DVM?
完成的
添加一条评论
添加你的答案
Mark Lynch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 54
