跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Data recovery from late 2013 MBP SSD
My late 2013 model MacBook Pro Retina 15” got wet when we had a pipe burst and won’t power on at all. I’ve purchased a 2015 model to replace it.
I’ve removed the SSD from the 2013 laptop, have an mSATA to SATA adapter (with 2 USB plugs), and have been trying to get the new laptop to read the old drive. I keep getting a message saying the the USB device is drawing too much power.
Your thoughts are appreciated.
Sure thing. Here’s a link to the item:
https://www.amazon.com/gp/product/B06XHG...
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Can you give us the details of the adapter you are trying to use. I suspect you have the wrong one.
完成的
Adapters are always a caveat with these Apple blade Ssd and it might be your culprit in this case. However, I'd ask for @danj help, he's probably the most knowledgeable Pro in this field.
完成的
Copy that. Thank you!
完成的
Thanks, All. We have an identical situation with my husband's MacBook Pro, but his is an older model--its a 2010. I would try to read that hard drive from my new (2015) laptop.
Thanks again.
完成的
添加一条评论
1个答案
最有帮助的答案
Sadly that unit won’t work. Apple uses a custom drive you’ll need this case: OWC Envoy Pro You might find one on Amazon or eBay used (cheaper)
这个答案有帮助吗?
得分 4
3条评论:
Ok, got it. Thanks so much for your input.
完成的
Note if any appliance/battery hdd's etc all phones also has been wet
Open all & let to dry for days in a warm place
i've dropped phones in pools a lot as i used to work on swimming pools _
i grabbed them out asap & opened on the car dash in sun
1 hr it worked :) 95% did
* note i've had ssd hdd that didnt work in draws for years BUT then i got this app that rescaned & clean it free
95% WORKED AGAIN ONCE CLEANED PROPERly formatted
the others i took apart for the magnets :) > trying find that app for you uha
> here this is ace (Y) Partition Wizard Home Edition 4.0
hope u read this incase more crap happens
完成的
Thank you! More info is always better.
完成的
添加一条评论
添加你的答案
Leah Springman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,254
