跳转到主内容
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
50 个问题 查看全部
问题已关闭
How do you make external display the main display? My diplay is,broken
I used to be Computer Guy, but now, I am just Corey. I forgot my password. How do you make an external display the main display because I can't see a thing on the computer's display because there is no display. I broke the display a long time ago. Can ANYBODY help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
After you get the external monitor working, start up from you system installation disk and go to Utilities > Change password.
这个答案有帮助吗?
得分 2
9条评论:
I can't do that because I can't see anything.
完成的
Did you connect an external monitor first?
完成的
No, becuase it does not work as you can see in the comment above.
完成的
Sounds like you have a bigger problem than the monitor. Leave the external plugged in and try restarting. Note anything that takes place that might give us a clue as to why the machine will not start.
完成的
Once I turn the external monitor on, the computer is just starting up. Then, the external monitor says "No Signal" because it does not sense the computer and shuts down. How can I stop this? It is an Acer display.
完成的
显示更多的4条评论
添加一条评论
最有帮助的答案
Connect an external monitor, then turn it on, before you turn the laptop on. Hopefully, the Powerbook will detect it automatically, so you can see things on the external monitor.
这个答案有帮助吗?
得分 2
1条评论:
It didn't work. The display keeps turning off before I can turn the computer on. How can I make it work?
完成的
添加一条评论
the osx needs to boot then it may see the ex display ?? now you will need to make it a mirror or the laptop this is hard to do as you will need to see the laptop display.?? make a new disk drive on a bowerbook g4 as this boots on that machine make this a mirror and then put your laptop (t) on boot on the laptop you will see your hard drive open it make it a mirror and then // reboot and it work with you ex display only after osx has booted .
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 1,409
