跳转到主内容
Model A1320 / 8 or 16 GB capacity
156 个问题 查看全部
New battery won't charge
Opened the ipod and measured the voltage output with a multimeter in the 3 weld battery points. Got zero volts even with the ipod working connected to USB...
Then measured the output of a new battery and got 5V, once i soldered it also got 0V from the battery! Dessoldered and it has 5V again.
Have no idea what to do... i guess the charging circuit is faulty but what can i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Check your dock connector for any shortening of the pins, i.e. broken or bend pins as well as corrosion. Check and clean the logic board of all corrosion. Check the solder pads for any shortening out of the points. Check for broken traces on your logic board. If none of that worked, I think its time for a new logic board. Good Luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
BOL 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,072
