跳转到主内容
LG在2016年9月29日发布的LG V10的后继产品,类似LG G5。LG V20分为F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996, and VS995数个不同型号。同时,提供了钛金灰、粉色等不同颜色。
Is it my battery or phone?
Hi. So my phone got peed on by a cat. It didn't seem like it had much damage and the battery seemed untouched by the urine, but I turned my phone off and let it dry with the battery set aside. Just in case. I did get some pee in my phone as the little circle that changes color when your phone is water damaged, changed color. That night my phone shut off on me twice, and from then it escalated. It is now overheating with any use and the battery won't even register with the phone half the time. Whether or not its charging. I tried charging my phone without the battery and it will show up with a logo to put a battery in, then when I put the battery back in, it doesn't register. I got it to briefly work after some persistence but I don't think it'll last long. The issues are getting worse and it's only been 4 days. Is this more of a battery issue from water corrosion/damage or is my phone on its way to die?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @awesomepants
As you know any liquid (except distilled water) and electronics and electricity are not a good mix.
The impurities in the liquid causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and continues until it has been cleaned properly
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies),to remove all traces of corrosion and liquids. Do not use "rubbing alcohol" as in some cases this is only 70% or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that in general, describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit LG V20 repair guides which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 2
1条评论:
Jayeff is correct.
完成的
添加一条评论
添加你的答案
Tash 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 135
