iPhone 5s rebooting loop after battery replacement
I recently changed my battery. After that everything seemed to worked just fine for a couple of hours. But when a was trying to calibrate the battery, doing a fully discharge, and then charge it, never turned on and began rebooting loop with a red screen that shows up sometimes.
I just have spend all my day trying to fix it with out solution.
- First I tried to do a hard restart;
- I changed display, (my old display works fine);
- I took out from display the proximity camera flex cable;
- Using the original battery.
I just don't know what else can be.
Please help me
2条评论
try putting the old battery back in, if it works as it did before then you know you have a dud new battery. check the charge in the new battery-it may be too low to charge (so when you allowed the phone to go flat it cant recharge) send it back..it will never come good.
由 pollytintop 完成的
Hi! Done, didn't work. It still rebooting :(
由 PJBG 完成的
