跳转到主内容
Can be used as a space heater or decoration.
5 个问题 查看全部
Is This Safe To Plug Into an extension cord or power strip?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
How many AMPs does it pull?
完成的
添加一条评论
2个答案
Hi @bunnybunny
Use the below link for a gauge.
https://www.electricalsafetyfirst.org.uk...
For safety , do not overload those.
这个答案有帮助吗?
得分 0
添加一条评论
Typically for this type of device, it is not recommended to use any type of extension cord. If you must use one due to placement for safety, use one rated for the current required by the fireplace. This should be marked on a plate on the back. If in doubt, use a cord with a higher rating. In other words, if this is rated to use 15 Amps of power, I would recommend at least a 14 gauge extension. Better still would be a 12 gauge.
Keep the extension as short as possible too.
Check with the local electrical inspector as well. Sometimes, insurance won't cover a loss if something is done counter to standard practice or recommendation.
Dan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jacob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 246
