跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2265 个问题 查看全部
Touch screen doesn't work
Hi guys
I have problem with my iPhone 7 touch screen !
It doesn't Response at all and it seems display has a problem too because it's filled with lots of small squares in background But homepage can be seen good !
I tried hard reset but it didn't fix . After I powered up my iPhone in Apple's logo there was a shadow of battery Percentage !
Did anyone face this problem ever?
Will restore help?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This sounds like a hardware problem for sure. So no, its not likely that a restore will do anything for your device.
If you have not dropped or damaged the device at all apple may replace it for free.
But it sounds as if the LCD screen has gone bad and needs to be replaced.
I'd check with apple first, and if they don't do it for free or cheap find someone reputable that will. Or do it yourself with an iFixit Guide!
iPhone 7屏幕总成更换
Hope that helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alireza sadeghi 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 12
总计 49
