跳转到主内容
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
Can I replace my HDD with an SSD
I have a MacBook Pro (17-inch, 2.4GHZ) with a dying hard drive, can I replace my HDD with a SSD? Will any SSD fit or there's certain specs that I need to be shopping for?
Thanks ahead for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Are you sure of your model? The model you've picked is the older Core2Duo. I'm thinking you have a newer 17" model, a late 2011 here's its specs: MacBook Pro 17" 2.4 GHz i7 (Late 2011) and here is the correct IFIXIT group: MacBook Pro 17" Unibody
完成的
添加一条评论
1个答案
已选择的解决方案
This is probably your machine:
https://everymac.com/systems/apple/macbo...
If so, it has a SATA I bus. 1.5 Gb/s. Most SSD drives are are 6 Gb/s. So make sure the drive you selects backward compatible to SATA I.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Palm Coast Lead 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 188
