跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone stuck in recovery mode, can’t restore/reset it.
I recently got my phone screen fixed. I turned it on and it was stuck in recovery mode with support.apple.com/iPhone/restore at the top of the iTunes logo. I tried restoring it with iTunes on my computer multiple times but it stops and error (9) pops up. Any suggestions on what to do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I had the same problem tried everything then I started just messing around so I took off the screen and tried updating it and it updated but then wouldn’t restart I then connected just the lcd and digitizer connector and left other connector unplugged and it updated and booted and is working fine now 🤷‍♂️
完成的
添加一条评论
2个答案
已选择的解决方案
Hello @abbylww0,
Error 9 is somewhat related to dropped connection.
There is more than one cause that can lead to this failure.
However, if the iPhone was charging normally before, does not have a charging port clogged with pocket lint, and was dropped (causing the screen to break) and bent (or possibly sat on), then you may very likely have a board level failure.
Technically, you may have a failed connection between a component known as the eeprom, and the CPU of the iPhone.
There are 3 popular ways to repair this: #1 reballing the CPU, very risky, very difficult and expensive; #2 drilling the CPU and placing "jumpers" to connect the CPU to the eeprom (risky, difficult, and expensive); #3 heating the CPU and applying pressure at the corner of the CPU where this failure occurs (very risky, could be only a temporary solution, can be cheaper).
Personally, my recommendation would be either to find someone who can offer you a no-fix-no-fee solution consisting of going over a few possible causes such as charging port, Tristar, NAND and NAND voltages, and finally option #2 = drilling the CPU (provided the cost is reasonable for both you and the technician performing the repair), OR discard it and buy a new (or used) phone. We've done option #2 before to retrieve data and were successful most of the times, and the most of those repairs lasted an acceptable amount of time afterwards.
这个答案有帮助吗?
得分 2
添加一条评论
Most of the time, you can restore your iPhone and get it back to normal from different iPhone errors, including iPhone stuck in boot loop issue. However, please be aware that putting iPhone into recovery mode to fix your iPhone will erase all data from your device. So it is recommended to backup all important files on your iOS device before the process.
Step 1. First of all, please don't connect your iPhone to the USB cord for now, but make the other side of USB connected to your computer.
Step 2. Run iTunes on your computer. And please be sure you have installed the latest iTunes on your computer. If not, go to Help > Check for Updates on iTunes to get a latest version of iTunes.
Step 3. Then turn off the iPhone by pressing and holding the Home and Power button on your iPhone.
Step 4. Next, please connect your iPhone to computer with the other side of USB cable after your iPhone has been turned off. Then continue to hold the Home button, and let go of it when a "Connect to iTunes" screen appears on your iPhone.
Step 5. Thus your iPhone has been in the recovery mode successfully. And you will receive a notification from iTunes, asking you to restore or update your iPhone. Just click Restore option to fix iPhone stuck in boot loop issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abby 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 35
总计 1,251
