跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab 4 8.0 Wi-Fi(型号为 SM-T330)于 2014 年 4 月 23 日发布。它搭载四核 1.2 GHz 处理器,并配有 300 万像素后置摄像头。
Can't connect external camera
Trying to connect an external endoscopic camera to my Samsung Tablet.
It has a micro USB port so connects directly to my tablet.
I downloaded the CameraFI app but it won't auto recognize the camera.
What am I missing??
Other info:
-tablet is Model number: SM-T230NU
-android version 4.4.2
-kernal version: 3.10.0-6808427
dpi@swdd6509#2
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I ran an OTG evaluation app on the tablet.
Turns out this unit doesn't have the capacity for running OTG hardware and manipulating/updating it is not always functional.
Sigh
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi ,
You need to connect the camera via an appropriate OTG cable, so that the tablet can supply power to the camera, if the camera hasn’t got its’ own power supply.
Checking online it appears that your tablet may not support OTG.
Here’s a link to an app that you can install to check if your tablet supports OTG. It does NOT provide OTG it just checks if it is available on your tablet.
If your tablet does support OTG search online for Samsung Galaxy SM-T230NU OTG cable to find suppliers.
If your tablet does not support OTG you may be able to use a powered USB hub to connect the camera through to the tablet’s USB port and see if that works. If it does, I appreciate that this is not a very convenient way to use it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
bradboehringer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 27
总计 2,480
