跳转到主内容
The Dell Latitude E7470 is marketed as an ultraportable business laptop that is part of Latitude’s Exx70 model line. The E7470 model was released in April 2016.
6 个问题 查看全部
Dell Latitude E7470 Replacement battery
I have a Dell Latitude E7470.
My battery is dead and it needs to be replaced.
Is it possible? (Some said the the motherboard needs to be replaced as well which sounds strange to me)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If battery is dead first check for a new battery, or you can use your charger first to verify if there is any issue with motherboard if laptop switches on without any issue that means you battery need replacement not your motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Youssef Ghrib 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 598
