跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
iPhone dead and itunes not recognizing after component replacement
Hi, I tried to replace my iphone LCD with a new one but I damaged the home button flex cable. During the process, I forgot to unplugged the battery and now the phone is totally dead and itunes not recognizing the phone. Do you have any idea what I should do or what component that might be broken? Thank you so much
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
In an iPhone 6 unlike with 6s there's no typical damage for replacing Lcd with battery attached. However other things can get shorted if power is flowing. Problem is since it's not a typical issue it could have happened anywhere you worked. Not to leave anything untried check if your phone boots when leaving home button cable unplugged from logic board. If that doesn't work try without other connectors (LCD, front Camera) if you have a pc to connect it to and check if iTunes recognizes it. In case nothing works you'll need to hand it over to a reputable tech who has schematics and tools to find out and fix what's wrong.
这个答案有帮助吗?
得分 2
1条评论:
I think the issue is on the motherboard, because I already disconnected all the front panel cable and it is still not working and itunes still not recognizing my phone. Thank you for your answer
完成的
添加一条评论
添加你的答案
Fadhil Mochammad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 34
