跳转到主内容
加入维修社区 - 创建账户
Lenovo 100s Chromebook-11IBY 是一款 11.6 英寸笔记本电脑,配备 1366 x 768 分辨率显示屏,电池续航时间长达 8 小时。
My computer won't turn on
I accidentally dropped my phone on my chromebook and the screen went all weird, as in line going vertically and horizontally while the rest of the page was still appearing. So I turned off the chromebook to see if turning it off and on again would work, but it hasn't turned on yet and it's been a couple hours. Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
where did the phone actually hit . was it in the process of booting up ? did you shut it down hard or normally ? does anything happen when you try to turn it on . like fan noise or beeps or lights ?
由完成的
The phone hit the space where the keyboard piece is connected to the screen, it was already booted up for a few hours, nothing happens when I try to turn it on, just a black screen.
由完成的
I think it might be the ribbon cable that connects from the screen to the motherboard. If it is lose the screen will have lines or may not turn on at all. It's an easy fix, as all you do is slide it back in place. Unless the LCD is cracked or something else has caused the problem hopefully this helps.
由完成的
There is no cable that I can see. I don't think it's that.
由完成的
Look at that image image and see if you see anything simaler if not let me know.
https://encrypted-tbn0.gstatic.com/image...
由完成的
添加一条评论
1个答案
已选择的解决方案
@cyrushart5 this sounds like you may have damaged the power button . there are cables connected to the keyboard in this area that connect to the motherboard .Open the laptopand check the wiring where the keyboard connects to the motherboard . While your in the computer disconnect the battery while your working on it . This accomplishes 2 things 1 static discharge and 2 clears memory as you cannot physically remove the memory from this as it is soldered to the board. Now while your in there check the two connectors to the keyboard show in red You may also want to check the video cable connector in the upper left hand corner of the same pic check the cable for damage and check the connector is still connected properly also follow the wire into the screen byremoving the bezel check all the wire for breaks and follow it to the back of the screen and check the connection there. Once you've reconnected everything and a satisfied everything is in order hold down the power button on the keyboard for 60 seconds . Then reconnect the battery reassemble the keyboard and bezel , then try to reboot the computer. Hope this helps
Lenovo 100s Chromebook-11IBY 电池图片
指南
Lenovo 100s Chromebook-11IBY 电池更换
难度:
中等
5 - 10 minutes
Lenovo 100s Chromebook-11IBY 屏幕图片
指南
Lenovo 100s Chromebook-11IBY 屏幕更换
难度:
中等
10 - 15 minutes
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your help!
由完成的
添加一条评论
添加你的答案
Cyrus Hart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 805
