跳转到主内容
Plastic seating devices for patios, poolsides and bachelor pads.
3 个问题 查看全部
Damage to clear chair
There was a number written on bottom of clear acrylic chair I purchased. I tried to remove it first with glass cleaner. No luck. Then I used nail polish remover. It removed writing (looked like black sharpie) but left area foggy, no longer clear. How can I restore?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Nail polish remover generally contains acetone or ethyl acetate both of which dissolve plastic. You could possibly buff it out but you are going to make a much larger area involved. IMHO further repair attempts are going to be futile. Live with it.
这个答案有帮助吗?
得分 5
添加一条评论
Lookup a technique called "chemical polishing". It uses a solvent of the material and a way of "rolling" the papertowel / rag so only fresh solvent is wiping the surface. I do it on car headlight lenses, but it took a fair amount of practice. I use a liquid acrylic glue, but straight acetone should work.
这个答案有帮助吗?
得分 1
添加一条评论
Paint Thinner - oil based, great discoloration remover and will make the PVC or plastic shine - use dawn dish detergent to clean the oily residue after you remove all the stains.
这个答案有帮助吗?
得分 1
添加一条评论
Next time try ISO alcohol. I find it removes permanent marker ink.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marilyn Hartley 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 29
过去 30 天: 87
总计 1,705
