How to correct Temperature Sensor failure
I have a Temperature Sensor failure on the cooling system test.
Can anyone help?
Try opening your Macbook bottom and check the fan and the heatsink are not clogged with dust. Since the Macbook has been around for 4/5 years a thermal paste check and replacement might be in order too. That's how you can possibly correct the temperature, you can't correct the sensor. You can use the following guide for help: 交换MacBook Pro 13''Retina显示器2013年末期版本的散热铁
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 251
1条评论
Can you give use the error message or tell us which sensor.
由 DanJ 完成的
