跳转到主内容
加入维修社区 - 创建账户
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
How do I bypass stuck key code?
My post keeps saying it’s deleted....?
PLEASE HELP! I have a Kenmore washer Model # 110.21102012. I have a lid lock light that keeps blinking.... Googled issues... did a diagnostic test on it and keep getting F2E1 code back... means Stuck Key. How do I fix it or bypass it?
Things I’ve already done: Replaced lid lock mechanism. Check main control board for damage. Nothing has worked. Washer runs and fills with water for approximately 10-15 seconds then stops and lid lock light blinks with a clicking noise. When I tried to do a calibration it runs for about 15 seconds of it and shuts off.
Please help. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If the board does not reset by unplugging it for five minutes, then you can try to take a hairdryer and run the heat back and forth over the user control panel and see if the key will unstick if not you will need to replace the user interface board.
这个答案有帮助吗?
得分 1
1条评论:
When using the hair dryer, how can you tell what key is stuck?
完成的
添加一条评论
Just run it back an forth over all of them
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ronica 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,361
