跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 个问题 查看全部
Logicboard compatibility of ipad 5 and ipad A1475
I am looking for a logic board for my ipad air A1475. I see some suppliers offering logic boards for ipad 5 wifi. Can I use an ipad5 wifi logic board in my damaged ipad A1475 ? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Yes, they are the same iPad called by different names. You just have to make sure the one you're buying is for A1475, since other iPad Air boards might be wifi only, without the 4g cellular part.
这个答案有帮助吗?
得分 2
3条评论:
Thanks for the helpful comment. I have managed to get an unlocked logic board for a1475 wifi+4g cellular with 64 Gb memory. I hope, this would be ok for the faulty board (which had 32 Gb memory).
完成的
@dmahapatra It will be ok, you'll only have a bigger storage available, no other differences between the two boards in size or other smaller parts. You can get help from the following guide in your replacement:
iPad Air LTE Logic Board Replacement
Enjoy :)
完成的
Thank you so much.
完成的
添加一条评论
添加你的答案
Durga Mahapatra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 859
