跳转到主内容
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26 个问题 查看全部
Why does my Chromebook keep flashing to a very dim lit screen?
So I was watching YouTube and then my chromebook flashed to a very dim lit screen (you could kind of make something out if you held it up to light). It kept doing this over and over again. I tried turning it off and on again but it even did it on the log in screen. How can I fix this and what is wrong with it??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi.
How much dim isit?can you see easly or not?
First couse is battery low.
Second is performance setting or something like that.
Third is backlight problem and its reffer to motherboard or backlight self.
这个答案有帮助吗?
得分 0
添加一条评论
Probably LED ribbon cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jemma Rose 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 9
总计 306
