跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
Fixing Skin temperature sensor to LCD skin
What is needed to fix iMac A1419 27" LCD Display Screen Skin Temperature Temp Sensor to LCD screen skin.
Update (07/07/2018)
I have replaced the screen and had to transfer the temperature sensor from the old to the new screen. I noticed that the sensor was attached to the rear of the screen with what looked like a bit of glue from a glue gun. Additionally it was covered with a piece of black tape.
Is this special type of glue for heat transfer or can I use a glue gun, and can I use any tape to cover it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Can you explain a bit deeper here. Is AHT reporting a failure or did you damage it some how?
完成的
添加一条评论
2个答案
已选择的解决方案
Only the sensor part is thermally sensitive so you can use any heat resistant tape like: Polyimide Tape. Many off the shelf tapes adhesives breakdown from heat & time.
Make sure the sensor body makes good contact to the mount point I would clean both surfaces and use a heat gun glue to hold it in place on the top just like how Apple did it.
108 foot rolls of Polyimide tape. Perfect match with OEM Apple Part# 922-1731 tape. Half-inch (.5") width.图片
产品
Polyimide Tape
$9.99
这个答案有帮助吗?
得分 1
添加一条评论
Do you know what denomination value of the sensor ? Is it resistive? Trying to fix my iMac and multimeter measures that sensor as an open circuit. iMac Late 2012 ....
这个答案有帮助吗?
得分 0
6条评论:
You'll need to use the diode test as it's a transistor.
完成的
Dan ,Thanks for the info...i should have assumed it is a transistor...got 3 legs on it!
i've got it! 2 legs connected together! But still ...my multimeter is silent on me here and all i see on a screen "OL" :)
Im awaiting for a new sensor to come on Wednesday.Will keep you informed here....
完成的
...It seems the LCD skin sensor was ok after replacing with the new one nothing has changed.Need to get thunderbolt adapter to hookup external display and run Diagnostics!
完成的
Lets get a better look at the thermal sensors, install this app TG Pro take a snapshot of the main window showing all of the sensors and fan and post it here for us to see 在已经存在的问题里加入图片
完成的
Dan thanks for help and not giving up on my aging iMac! Waiting for Thunderbolt adapter to show up.....
After connecting thunderbolt adapter from iMac to my hdmi equipped monitor the screen is black ......not sure at this point what to do.....
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Frans 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 1,726
