跳转到主内容
Is there any way to remove scratches from the screen of a Moto Z2 For?
My Moto Z2 Force screen is made of plastic and therefore I was told that this phone would not be a to break but lately I have noticed these little scratches on my phone which is quite disturbing so if you could help some how I'd appreciate it. -Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi!
Unfortunately, the screens of the Moto Z2 Force does scratch easier than that of the original Z Force and you cannot get a free replacement from Motorola like you could for the Z. But you can buy a new upper layer from them and I believe they also install it for you. Have a look here: https://www.motorola.com/us/products/mot...
As for removing the scratces yourself... I do not think that is possible, all you can do is preventing any more scratces by applying a screen protector (cheap, plastic ones are just fine, you wouldn't need the fancy, thick glass ones since the screen is already shatterproof) like this one.
这个答案有帮助吗?
得分 1
添加一条评论
http://homeguides.sfgate.com/remove-scra...
这个答案有帮助吗?
得分 1
添加一条评论
I do believe you could use cerium oxide. It's used for polishing watch glass that's not crystal glass. Hesalite glass was common on watches and was easily polished with toothpaste! I guess the z has some kind of acrylic glass and then cerium will work fine. Be careful! It's toxic and you can easily make the screen wavy if you rub too much.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aracely 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,278
