跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
330 个问题 查看全部
Need to replace HDD
Hey Dan,
Is the Aura SSD a blade SSD?
My issue is I NEED to replace my HDD because I can't back it up due to an update, rendering my iMac useless (literally)!
So I would prefer to just get a regular SSD with an adapter rather than going the trouble of replacing the blade SSD. This way I can plug in my old HDD after and transfer data.
Does this make sense?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What is your exact model? Look it up here using your systems Serial Number EveryMac - Lookup as you had piggy-backed onto someones else's question I want to make sure I aim you correctly.
完成的
Why do you need to replace the HDD?
What do you mean you can't back it up because of an update?
完成的
添加一条评论
2个答案
Here are the following upgrade options for your Mac: https://eshop.macsales.com/upgrades/imac...?
It would be easier to replace the 3.5" inch HDD with a 2.5" SSD. Taking apart the iMac is a hassle already. You shouldn't take it apart if you aren't a professional.
这个答案有帮助吗?
得分 0
添加一条评论
Of course it makes sense, the blade SSD is expensive and slower than a standard m.2. Adapter does work, i got on in my retina MBP
Update (24.07.2018)
27英寸iMac(EMC 2546)刀锋SSD的更换
Thats how it is done.
If you changed a Iphone Display htan u can do this aswell.
I changed my Blade SSD with a M.2 SSD:
https://www.amazon.de/Green-Interne-Fest...
The M.2 SSD is around 30 percent faster!
The stock does 420 MB/s and the M.2 with adapter does about 550 MB/s
这个答案有帮助吗?
得分 -2
添加一条评论
添加你的答案
Kenzie Yango 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 77
