跳转到主内容
加入维修社区 - 创建账户
Skullcandy Crushers 搭载了两个扬声器驱动单元,分别是 Sensation 55™ 和 REX40™,带来出色的音质和你能感受到的低音。该产品于 2013 年 3 月 20 日发布,型号为 S6SCFZ-072。
Left side won't play any audio
So I've put the batterty in and all that fun stuff, I've even replaced the battery a couple of time and none of them seem to work so I was wondering how I could fix the audio only coming out of the right side
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
that's a pretty easy thing to diagnose. id say 9/10 times its a disconnect in the audio wire.
The labor, on the other hand, is usually extensive.
-Youll need to open the device, and disassemble the device nearly all the way.
-Start by verifying no cold joints on the soldering points of the speakers, and connecting wires. apply fresh solder to all joints, and test.
-Check the continuity on the wire going through the band. if thats not connecting properly, replace that wire.
-Verify speaker function. Put a low voltage, mid-frequency signal into the speaker to verify sound output. if it doesn't buzz, you will likely have to replace the speaker.
usually, it is one of the above that cause the issue, however, it is possible to have a board level failure.
这个答案有帮助吗?
得分 1
6条评论:
Sadly I don't have access to soldering kits at this time,do you happen to know of a store I can take it to get it fixed?
由完成的 分享
that would be dependent on each city. you will need to take it to a repair shop. these shops are usually privately owned, so each town will have their own stores.
a quick local search for electronics repair may help.
由完成的 分享
Many thanks Scott
由完成的 分享
I am having a similar problem to this person. Although when i turn my headphones on and when they connect, I can hear the voice on both sides. I can only hear one side when i play anything.
由完成的 分享
I have this problem with the right speaker, a friend told me he dropped it causing the right side to completely stop working. I've played music through them and found that although both speakers vibrate, the right one does not play any of the music. I've struggled trying to find the speaker model number so I could replace it, where could I find these speakers?
由完成的 分享
显示更多的1条评论
添加一条评论
添加你的答案
Griffin Perry 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 42
总计 4,152
