跳转到主内容
The HTC Desire 816 features a 5.5-inch display with a 1280x720 resolution, 13 mp rear facing camera and HTC BoomSound.
Why is my phone not charging anymore?
My HtC Desire 816 just stopped charging. I havent had any problems before, and it was holding a charge just fine until yesterday. Now it wont turn on or charge. I did not injure it in any way. What can I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Have you tried a different charger, or a different charger cord?
Try connecting it to a computer and see if it starts to charge.
If it still doesn't charge, use a strong light and a magnifying glass to inspect the phone's charge port.
Ensure that all the pins are there and that they are straight and parallel with each other. Also check that there is no lint etc. trapped in the port enclosure.
If there is, DO NOT use a pin or probe to try and clear it. You may damage the pins or the internal components. Use a vacuum cleaner to try and suck it out. If it still won't budge, gently use a wooden toothpick to clear the obstruction.
If the port enclosure seems clear then the phone will have to be opened and further inspected as to the cause of the problem.
Here’s a link to the ifixit HTC Desire 816 guides which may be of some help.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Gigi Newman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 824
