跳转到主内容
Series of HP Pavilion laptops released in 2015. The 15-p is more difficult to service then later 15-x models.
HP pavilion disk dive scews
Hi, i have a hp pavilion and im trying to upgrade the hdd to a ssd but ive got stuck trying the remove the screws just above the disk drive it seems to be a very small Crosshead/phillips screw does anyone have the screwdriver size
many thanks
Michael
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Look very closely at the screw heads. Are you sure they're not Torx (6-pointed star)? Press very hard on the screwdriver - if it slips you'll damage the screw head and then it may be almost impossible to remove.
完成的
添加一条评论
2个答案
最有帮助的答案
The laptop uses Phillips #00 screws like every other PC laptop I’ve worked on - but there are multiple lengths that were used. If this is your first run working on the laptop, you really need to sort the screws. I didn’t bother in the guide because I know where they go and have dealt with enough HP machines to know.
In order to get to the hard drive, the ENTIRE laptop needs to be taken apart. I have a guide up for this, but there are multiple reports of a specific variation in the battery bay I never had to deal with where there are two extra screws that need to be removed if yours isn't an “exact match”. No other differences have been reported so far.
Once you remove the palmrest, the hard drive is able to come out without additional screws. The issue on this laptop is how annoying it is to replace. The guide can be found here.
这个答案有帮助吗?
得分 1
添加一条评论
i dont have the driver specification, but if it IS a phillips head, then you will likely be looking at Ph000, or Ph00. These are the most common small phillips to use in electronics.
i would suggest purchasing a precision toolkit before attempting any electronics repairs. All toolkits will include these two sizes.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
michael greensmith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 3,901
