跳转到主内容
The Kenmore Direct Drive is a washing machine by Kenmore.
Spin basket (drum) does turn in spin cycle
I have a Kenmore 400 (model #: 11029422801) and the washer goes through the wash cycle without problem until it hits the spin cycle. During the rinse cycle, it appeared that the agitator and drum spun in tandem when the water was draining. But in the spin cycle, only the agitator spun and not the drum. I've been advised that this may point to a faulty timer, but a bad clutch seems to make sense too.
I've already replaced the lid switch and that did nothing to address the problem.
Could you advise? I'm trying to decide which repair would solve this issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Take the agitator out and look to see if the bottom of the spin basket is broken out. If so you will have to replace the spin basket. A lot of these washers have a lifetime parts warranty on the spin basket. If the spin basket isn’t broken I believe the transmission is bad or the hub nut is loose. To check the hub nut you will have to remove the agitator coupling.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Mark J 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 679
